OIL PRESSURE LIGHT!!???
Old Jun 10, 2009 | 02:25 PM
trippy1313's Avatar
Default OIL PRESSURE LIGHT!!???
Hello, I have a 1990 Accord, stock f22 motor, and lately the oil pressure light starts flashing after I've driven it 10 miles or so... and I have no idea why, if I shut of the engine, and turn it right back on, it usually stays off for another 10 miles... any ideas why. The only variable I see are, that lately the weather has been much warmer than usual, mid-70s to high-80s. when its usually in the 50s-60s... and there is a very slow leak from the drain plug (thanks to jiffy lube). But the oil level was fine every time this has happened.
Please let me know your thought/ ideas.
Thanks,
Ken
Old Jun 10, 2009 | 03:59 PM
2KRacing_JM's Avatar
Default Re: OIL PRESSURE LIGHT!!???
If your oil level is correct, then pull the sensor out and have it checked, if the sensor is fine, then you got to check the wiring. The sensor might not be getting good ground.
Old Jun 10, 2009 | 04:23 PM
trippy1313's Avatar
I'll try that, is this a pretty common problem? I don't have my hanes manual on me... lol, where is this located, I'm sure I'll find it soon enough though.
Old Jun 10, 2009 | 04:29 PM
trippy1313's Avatar
Nevermind, I used the handy search feature, what a concept right? Ok I'll try that hopefully the next time I drive it, and let you guys know if that helped.
mmedcalf
Jun 14, 2017 10:07 AM
curtie94
Jan 31, 2012 06:16 PM
Bird86
Dec 21, 2011 04:49 PM
joker4096
May 2, 2010 08:27 PM
Solipsist
Nov 18, 2002 03:30 PM
