Almost complete GSR swap for sale
I have a GSR motor with tranny, wire harness, torque mounts, throttle cable, alternator, halfshaft, upper/lower radiator hoses, and heater hose.
All you will need are the axles, mounts, shift linkage, header and ECU. It is also missing a map sensor which can be found anywhere at a junkyard for cheap.
Motor has 80k on it. The motor is sitting in my shop. I can do a leak down test in front of you to show that it is in good condition. It doesn't burn oil or anything.
$2100 obo
email me for the quickest response.
vexcraigs@gmail.com
$2100 obo
vexcraigs@gmail.com
yea I bought it with a bent valve and fixed it. All cylinders have good compression now. Motor was missing more things when i bought it, but I tried to complete it as much as possible.
its a 1996. The guy said he will give me the shift linkage, ecu and itr head in about a week, but im not counting on it. if he does come through, those parts will go to the buyer. I also have spare b series axles with ripped boots to give away with the swap also.
B18c1turboedEK
Southeast (Sales)
Apr 12, 2006 04:06 AM
