1990 crx si with b18a1 swap won't start
Old Jun 10, 2009 | 11:20 AM
kuNGFu pANDA2o9's Avatar
Default 1990 crx si with b18a1 swap won't start
hey guys i have a 1990 crx si and i swapped in a b18a1...everything was plug in play car ran great for a couple of days then all a sudden it started dying out....thot it was either dizzy or fuel pump....put in a new dizzy then car starts up fine again but decided to change fuel pump anyways...so put in new fuel pump now car doesnt start again...cranks but wont start....i can hear the fuel pump working...car has spark....its shootin gas(not sure if its enuff).....need some help to figure out wats wrong...im replacing the fuel filter soon so we'll see if dats it....
Old Jun 10, 2009 | 01:36 PM
CReXplicit's Avatar
New User
Default Re: 1990 crx si with b18a1 swap won't start
check the timing, check the plug wires, recheck fuel pressure and spark...if the spark isnt strong enough, it wont start
Old Jun 10, 2009 | 04:42 PM
its not the timing the motor use to run great....plug wires are good also put in new spark plug and new dizzy...not sure about fuel pressure
Old Jun 10, 2009 | 04:43 PM
just put in brand new fuel filter car still doesnt start
Old Jun 10, 2009 | 08:21 PM
ryanevansoh's Avatar
main relay? are you hearing a hum from the fuel pump when you turn the car onto the "on" position?
Old Jun 10, 2009 | 10:07 PM
Main relay is good....the thing is the car use to starts up and runs great untill I put in a new fuel pump but the thing is I hear the fuel pump running and it also shoots out gas....
Old Jun 12, 2009 | 02:07 PM
does anyone thing its because of the vacuum hoses..??? cuz im not sure if i connected the hoses right...
Old Jun 13, 2009 | 08:17 AM
bump...help??
Old Jun 15, 2009 | 10:26 AM
PiKapp504's Avatar
Did you make sure to plug the new wires in the right order on the dizzy?
Old Jun 26, 2009 | 09:00 AM
yea all of it is in order....about to recheck fuel pump see wat happens after dat
Projekt CR-X
25
Mar 8, 2011 08:13 PM
bimmeracer
Jul 16, 2008 06:12 PM
accord-h22
Feb 13, 2007 04:45 PM
EGNA
Jul 12, 2006 03:31 PM
crxxrc
Feb 8, 2004 01:39 PM
