93 eg with b16a jdm swap
ok i put a jdm b16a into my eg hatch and it will start on ether (starting fluid) so i got curious i pulled the fuel rail and had my bro turn the key and all i see is one injector squirting.. could it be the ecu??? i originally had a ls swap a 01 b18b and everything ran when i pulled it and i never disconnected the fuel rail or the injectors from the wire harness so i dont get it ppl r sayn its my injectors but i dunno...
i also bought a p30 chipped ecu from monotech and he said its got a p73 setup in it and chipped to run 4500rpm vtec, 2 step launch 4500 rpm, red line 9200rpm, shift light 6800rpm,
could it be the 2 step since it aint turbo??? need help asap so close to finishing...
if i cant figure it out this guy wanna trade me a type r block wit gsr head so i might jus do that idk thanks in advance
baker
baker
2 step isnt just for turbo cars, its for any car that you want to launch for racing. that wont cause your injectors to not work.
are all the connections on the injector clips snapped down tight? which injector is getting the fuel out? sounds like you might have bad fuel pressure or something along those lines
injectors lock up the pintle?sp when they sit for a while in a wharehouse. i always use injectors from a known good motor when i do a swap. i`ve had alot of experience with swapping motors and i always swap the fuel rails when i put a new motor in.
i been messing with it aLL day went to the junk yard n got sum injectors off a d16z6 cuz mine were cracked.. the 1st cylinders injector is the only one that fires.. for some reason nothing is sucking thru the intake.. so im going to take it off and get a different one...
they were good injectors sum dumbass musta stepped on em or sumthin... couldnt find a fuel rail for a b16 so i just used the stuff from the ls swap... so far it just looks like theirs a reason y theirs nothing sucking thru the head the intake looks alot newer and dont look like pgmfi which is what is set up in my head os i think if i get a pgmfi one it might work.. im hoping atleast cuz its not getting fuel all the way for some reason
k i changed the intake turns out it wuz odb2 intake now i have this little box hoked into the back of the intake.. still seems like theirs sumthing wrong tho.. i put it back in time.. but could a valve be messed up or something sometimes this things gettn hard to crank .. i am really at my end with this motor.. bout to buy a different one
