vtec brake and rotor sizing
Old Jun 9, 2009 | 08:39 PM
autoluder's Avatar
Default vtec brake and rotor sizing
I recently upgraded my h23 brake setup to the h22 setup. And got the Axxis Ultimate performance street pads and noticed that even though the vtec pad is longer and the rotor is larger the pad is shorter and didn't utilize the whole rotor braking area. And had stopped by a couple parts stores and they had vtec pads that were 1-3/4" tall to 1-7/8". But the h23 brake pads were slightly taller and used the whole rotor brake area. Vtec owners, do you have this same issue?
Old Jun 9, 2009 | 09:21 PM
InvaderTrax's Avatar
Default Re: vtec brake and rotor sizing
What brand rotor is that? Mine don't have that lip. They're flat across until you get to the hat. Anyway, I have HPS and I really don't want to pull it apart to measure them. Just assume they're big enough to be within spec and go with it
Old Jun 10, 2009 | 04:43 AM
autoluder's Avatar
rabestos rotors..
Old Jun 10, 2009 | 09:20 AM
NirVTEC's Avatar
[QUOTE=autoluder;38848691]I recently upgraded my h23 brake setup to the h22 setup. And got the Axxis Ultimate performance street pads QUOTE]
Ugghhh.....why did you even bother with those pads?
Are you sure they are for H22 and NOT H23?
I upgraded to VTEC calipers/rotors because the BEST H23 pads were Axxis Ultimates and thats NOT good enough for me........
With those pads, you should have just stuck with H23 setup......
Old Jun 10, 2009 | 03:45 PM
autoluder's Avatar
if i touch the brakes fast at 30mph i can lock the tires, theres already an increased amount of braking power, and all the other pads were too expensive. Plus Im using the pads on the street.
FRKWOO
12
Mar 11, 2010 10:09 PM
vtec128
Oct 20, 2009 07:57 AM
hellsyea2020
Jan 16, 2006 12:43 PM
B-B-K
Feb 17, 2004 09:47 AM
Brad
Jun 17, 2003 03:22 AM
