Fuuuuuu Electrical problem ?
Old Jun 9, 2009 | 04:53 PM
le0ftw's Avatar
KOBE IS GOD
Default Fuuuuuu Electrical problem ?
Okay well after I installed a header I wanted to make my engine bay look good and I powerwashed it with water of course. bad ****ing idea ! now here are my symptoms:
The battery does not charge.
The power dies once the lights are turned on.
The light flicker on and off.
I'm getting no signs of a bad alternator (brake light, oil light, battery light dont go on)
The RPM and MPH gauges dont work.
What could be the deal ? I'm taking it to an electrician and my friend installed another alternator and I got the same deal.
Old Jun 9, 2009 | 05:24 PM
omgwtfbbq's Avatar
Default Re: Fuuuuuu Electrical problem ?
sounds like you fried a couple things. First things first, check all your fuses and relay.
Second, a bad alternator is not determined by lights dimming or battery lights flickering...it is determined by checking the voltage. If you do not know how to do this, take your car to a mechanic.
Also, an electrician is not the answer...an auto mechanic who knows car electrical systems is, but you mgiht be wasting money if you don't check the simple stuff first
. Most of the equipment under the hood can handle a little water, no problem. The most important thing that you do not want to get wet, is your distributor.
I've washed many engines and normally the only problem I will see is a CEL that will come on for a little while, and then go away when the engine is completely dry and warmed up.
Anyway, back to basics. Check all your fuses and relays, both under the hood, and under the dash on the driver side...then let us know.
Old Jun 9, 2009 | 07:25 PM
sde780's Avatar
leoftl
like previous guy said, check fuses
Old Jun 9, 2009 | 07:36 PM
turboteg90's Avatar
pm for noodz
take this to gdd.
Old Jun 9, 2009 | 07:41 PM
Former User's Avatar
Also dry all the electrical connectors, fuse box, distributor, etc. with compressed air.
Old Jun 9, 2009 | 09:33 PM
omgwtfbbq's Avatar
I would use dielectrcal grease on these connections that got wet, to prevent corrosion later.
stocker2shocker91
Nov 11, 2015 05:02 PM
homero
Apr 4, 2012 10:39 AM
ezol
Aug 19, 2007 09:26 AM
bard329
Jun 20, 2006 07:46 PM
Keno20
Jul 3, 2005 07:27 PM
