12 compression too high
Old Jun 9, 2009 | 04:21 PM
jawsiiv's Avatar
Default 12 compression too high
Did the compression ratio and it gives me 12.000 compression. THe pistons which are ZC will be placed in my B7 Block and Z6 head. Is this compression to high for daily driving, and is there anything I can do to drop the compression???
Old Jun 9, 2009 | 04:52 PM
civic_driver's Avatar
Default Re: 12 compression too high
An easy solution is to use a thicker headgasket.
Old Jun 9, 2009 | 05:02 PM
jawsiiv's Avatar
Y8??
Old Jun 9, 2009 | 08:30 PM
medorihb's Avatar
its a 3 layer gasket...and it should be fine for daily driving.
Old Jun 9, 2009 | 09:15 PM
98civdx's Avatar
Master Detailer
yes on the 3 layer, you should be ok for a dd. just only give her the best gas.
Old Jun 10, 2009 | 04:49 AM
ddd4114's Avatar
I just tried the combo in http://www.zealautowerks.com/dseries.html, and I'm getting 10.5:1. How are you getting 12:1?
If it's 10.5:1, don't worry about it. However, ZC pistons and a z6 head doesn't seem like a great combination for 12:1 SCR, even with 93 octane. What camshaft will you be using?
otek // ek.dipn
Jul 27, 2010 07:08 PM
Firstoost
Apr 26, 2006 05:30 PM
boosted_zc
Sep 28, 2003 07:30 AM
89civichatchback
Jun 2, 2003 11:48 AM
