tons of b series parts n turbo parts
i have all my stuff for sale prices r obo and for b series
fully fully built gsr head- stage 1 pnp all werk done by kms engineering- 1000
crane cams and cam gears- 400
power plus gsr intake manifold thats been ported out on throttle body side and runners along with the throttle body ported at 74mm-200
golden eagle fuel rail for b series-30-sold
precision 880's-100
obd2 b series dizzy-50-sold
custom fab turbo manifold(mini ram)-100
cast iron turbo mani-30
tial wastegate-100
ebay greddy bov- 30
vortech air to water intercooler- 125
all the piping from my setup- 75
p28 ecu with the rtp board installed and boost control option with boost solenoid- 350
ctr crank pulley- 50
light weight flywheel and xtd stage 3 clutch-100
b16 block bored over to 81.5 with block guard n crank and ARP main studs and high flow oil pump from kms engineering-150
my ef shell with the etd traction bar installed and obd1 conversion harness-300
i also have my b series cable tranny with b16 hydro gears and welded diff-500
also have the linkanges n mounts for b series into an ef
also have b series starter n alternator
i have more **** so if you need other stuff juss
everything gone... sum1s comin to pick up the whole car as is
precision 880's-100
tial wastegate-100
ebay greddy bov- 30
pics of other stuff tomm when i drop tranny n pull motor out
as for the intercooler its 2.5 in and out... wut other specs do u need? mayb dimensions or wut?? pics will prolly help most... get em tomm
dylthomas
Aug 31, 2016 04:52 PM
could you also get me a pic of that valve cover?
