piston rings
Old Jun 9, 2009 | 12:17 PM
civicrolln's Avatar
New User
Default piston rings
hey i have cp pistons for an ls motor with low compression and the top ring broke as i was installing them. Is there any way i can use the stock rings and not run the risk of melting them? any other ideas would be appreciated thanks
Old Jun 9, 2009 | 04:37 PM
racebum's Avatar
Default Re: piston rings
call cp and buy one new ring?
redflaredcrx90's Avatar
you need A TOP COMPRESSION RING thats fits that fits that pistion so yes a stock one will fit if its brand new and is a 81mm ring if your useing a 81.5 mm pistion that you need a ring that fits that piston.
MastaFlyMason
Engine Machining & Assembly
Dec 14, 2017 04:08 PM
JJDub
May 31, 2017 07:30 AM
ZCHondaCRX91
Sep 14, 2015 04:23 PM
EJ8chu
Jun 16, 2008 05:26 PM
boosted k20
Dec 1, 2004 09:31 PM
