What Drains a Battery?
Old Aug 20, 2002 | 09:38 AM
SdAhd83's Avatar
Default What Drains a Battery?
What Drains a Battery?...i charged my battery and it was fine again, but the next day it was dead again, my fuses are bad, meaning my PW/PL dont work cuz of that....is that the problem?...i need to know whats draining my battery...thanks!
Old Aug 20, 2002 | 09:40 AM
Gennady's Avatar
New User
Default Re: What Drains a Battery? (SdAhd83)
Failed alternator, leaving your lights on? Try this, turn on your, and pull the battery, if it shuts off, its probebly your alternator. Can anyone back me up on that?
Old Aug 20, 2002 | 09:52 AM
Charlie Moua's Avatar
Default Re: What Drains a Battery? (Wont be beat)
I had similar problems. is you belts squeaking?
Old Aug 20, 2002 | 09:54 AM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:21 PM 11/17/2006
Old Aug 20, 2002 | 10:06 AM
Gennady's Avatar
New User
Default Re: What Drains a Battery? (schlit)
Well, if the system is fine, disconnecting the battery should not do anything, and everything should work fine because now the electrical system are running off the spinning of the alternator...this I know for fact.
Old Aug 20, 2002 | 12:16 PM
smokin rubber's Avatar
It sounds to me like the battery is D E A D.
Old Aug 20, 2002 | 12:19 PM
Gennady's Avatar
New User
Default Re: What Drains a Battery? (smokin rubber)
Ocums (sp) Razor?
Old Aug 20, 2002 | 12:28 PM
The_In_Kid's Avatar
Default Re: What Drains a Battery? (dohctwinn1)
yeah check for corrosion in the alternator plug...
i solved my problem by sticking tin foil in 2 of the plugs and it fixed most of the problem
Old Aug 20, 2002 | 04:36 PM
SdAhd83's Avatar
Default Re: What Drains a Battery? (The_In_Kid)
ok...the battery was dead so i recharged it and was new again....no lights were on no doors were open...the next day it was dead again...but everytime i tried to start it, it got worse, meaning the battery was dying more and more until it was toally dead again...my fuses are messed up...the PW/PL dont work...could that be it?...or should i just get a new alternator?
Old Aug 20, 2002 | 04:51 PM
the battery has seen its last days, it will not hold a charge. The fuses being blown should create less draw from the battery not more. Replace the fuses and the battery.
Old Aug 20, 2002 | 05:45 PM
SdAhd83's Avatar
ok thanks...ill replace the battery but its basically new we got it like within the past year...ah well and i need to change the fuses...thanks for all your help...everyone...more advice couldnt help i guess...
disposable
Jun 26, 2008 08:02 PM
Jizzo
Dec 18, 2007 03:43 PM
idewson
Aug 31, 2006 11:45 AM
Riceburner247
Oct 12, 2005 07:04 PM
BlowOff
Jun 11, 2002 07:08 PM
