'90 CRX Si Drive Axle Won't Come Off
Old Jun 9, 2009 | 08:24 AM
CW-ITR's Avatar
Default '90 CRX Si Drive Axle Won't Come Off
I'm trying to take out the driver side axle and no matter what I do, it won't come off. Well, it come loose about an inche and that's it. I even tried to fry it out with a small fry bar and no luck. Any idea?
Old Jun 9, 2009 | 08:28 AM
ef-hatchcrap's Avatar
Default Re: '90 CRX Si Drive Axle Won't Come Off
Are you trying to get it out of the hub or tranny?
Do you have the suspension taken apart to allow room for the axel to come out
Old Jun 9, 2009 | 09:03 AM
CW-ITR's Avatar
Off the tranny and all the suspension parts are off.
Old Jun 9, 2009 | 09:17 AM
ykni's Avatar
slide a fat flat head in between the tranny an axle an tap it up with a sledgy softly till it pops off ...thats what i did this weekend ...
Old Jun 9, 2009 | 09:31 AM
JackFlack's Avatar
You might have Fried it to long with that Fry Bar, and now it's to crispy.
Old Jun 9, 2009 | 10:31 AM
CW-ITR's Avatar
Haha!
Old Jun 9, 2009 | 10:35 AM
CW-ITR's Avatar
Thanks. Now, it make sense. The weight of the axle may have caused it to get cauhgt at the opening because of the tight clearance.
Old Jun 9, 2009 | 12:09 PM
skipbudlong's Avatar
That was my first good laugh of the day. Thank you.
Old Jun 9, 2009 | 12:37 PM
When I have that problem I just take the pickle fork stick between the tranny and axel and give it a puch and it should pop out
Old Jun 10, 2009 | 01:41 PM
CReXplicit's Avatar
New User
pry the axle from the tranny with a descent sized pry bar, then use a 5lb hammer and whack the axle shaft a few times while prying...POP! itll come right out
Old Jun 11, 2009 | 08:31 AM
CW-ITR's Avatar
Now, this, I got to try. So far, all other methods not working.
Old Jun 11, 2009 | 09:29 AM
DEIVIONCRX's Avatar
Ive even had to hammer a chisel between the case and axle to get them to come out sometimes.
Old Jun 11, 2009 | 01:22 PM
EL Vap133's Avatar
Pry bar works good for me.
88aeFC3S
Dec 23, 2010 07:43 AM
rice a roni
21
Apr 21, 2006 04:45 PM
crxzcracer
15
Sep 21, 2005 11:17 AM
ek_slut
May 12, 2005 08:11 PM
crxagogo
Oct 27, 2002 02:59 PM
