Changing out tranny fluid...drain/fill bolts are where?
Old Aug 20, 2002 | 09:18 AM
Quik89Si's Avatar
Default Changing out tranny fluid...drain/fill bolts are where?
Alright, looking at my tranny case from the passenger side of the car, I see two plug-looking bolts...the weird thing is that they're not bolts, like the oil pan drain bolt, they have square cutouts in them, which makes it look like you need a special key to get them out!
Am I looking in the right place? How do I go about doing this?
Thanks!!
Alex
Old Aug 20, 2002 | 09:24 AM
SuperCivic's Avatar
Default Re: Changing out tranny fluid...drain/fill bolts are where? (Quik89Si)
yup..use a 3/8s rachet. don't take out anything with a hex hole, that's not the right ones. the drain plug should be a 3/8s cut out and if i remember right the fill plug is a few inches above it..17mm.
Old Aug 20, 2002 | 09:27 AM
Quik89Si's Avatar
Default Re: Changing out tranny fluid...drain/fill bolts are where? (SuperCivic)
Cool, thanks for the quik reply...you think I'll be able to do this with the car on the ground?
Alex
Old Aug 20, 2002 | 09:29 AM
SuperCivic's Avatar
last time i did mine i had to jack it up to get the drain plug out..then to fill it i used a funnel w/ about a 2 ft piece of hose on it. fill til the fluid runs out..just over 2 quarts for a b series.
Old Aug 20, 2002 | 09:37 AM
Quik89Si's Avatar
Oh, you've got a B in there...I've got the original D16. The drain/fill plugs on mine are actually both for a 3/8ths ratchet. I haven't done that much work on my car, so this was something new for me, to see something that just uses the ratchet head.
Do I need new crush washers for both bolts? On my car, it looks like there has been some leakage around the bolts on my tranny.
The shifting acion in 1st and 2nd is kinda stiff...will changing the fluid out (Honda MTF) help this at all?
Thanks again!
Alex
Old Aug 20, 2002 | 09:42 AM
SuperCivic's Avatar
Thanks again!
Alex
yeah, i'd say replace your washers on the plugs..always use honda MTF. it's worth the extra few bucks. good luck with it
Old Aug 20, 2002 | 02:16 PM
ScottEK's Avatar
Where can you pick up Honda MTF, and what is different from motor oil with SG rating?
Old Aug 20, 2002 | 02:31 PM
Quik89Si's Avatar
Default Re: Changing out tranny fluid...drain/fill bolts are where? (beta13)
Honda dealer.
Supposed to be better for your synchro's, other than that I really don't know the difference...I just follow what Honda says.
Right now, my Honda is saying, "Hi, my Tranny fill and drain bolts are both locked tighter than Britney Spears, and they're not coming off *******!!! BUAHAHA!!!"
DAMNIT, there went my whole afternoon, and I'm just going to have to take it somewhere now.
Alex
Old Aug 20, 2002 | 02:42 PM
whizdumb's Avatar
http://www.c-speedracing.com/howto/t...ransfluid.html
Old Aug 20, 2002 | 05:00 PM
APEX CRX's Avatar
DUDE!!!! you need to use a big *** 3/8 breaker bar if those little bitches have'nt been opened in a long time
Old Aug 20, 2002 | 06:37 PM
outlaw_78ca's Avatar
Ok does the D15/EW2 use the same trans as the D16? and as for trans fluid i have been hearing that some type of gear oil produced by Redline works good i cannot remember the exact name at the moment i think it was Mtr 70 or something like that but i also heard that the Redline Shockproof Gear oil works well too
Old Aug 20, 2002 | 06:48 PM
rickshank's Avatar
New User
Very Important note::: Make sure to work on the fill bolt first. If you get the drain open, and can't get the top open, you've got yourself a big problem.
~ricky shank
Old Aug 20, 2002 | 10:55 PM
Quik89Si's Avatar
Default Re: Changing out tranny fluid...drain/fill bolts are where? (rickshank)
~ricky shank
Yup...I figured that one out...I couldn't get the fill bolt off today so I'll try another day...maybe pull on that breaker bar a little harder...or find another way to get it off. The ratchet wouldn't fit in the space, so I had to use a box-end wrench and try to make a bar fit over the end of that.
Thanks again for the help and advice, guys!
Alex
Old Aug 21, 2002 | 05:32 AM
SuperCivic's Avatar
Default Re: Changing out tranny fluid...drain/fill bolts are where? (outlaw_78ca)
i used redline mt-90 on my 300zx..good stuff, but 8 bucks a quart! honda mtf works for me.
Old Aug 21, 2002 | 01:33 PM
ScottEK's Avatar
From Valley Honda in IL,
2 Quarts of HMTF @ $7.36 a piece
1 Replacement Washer $1.01
RIP OFF
Old Aug 21, 2002 | 03:33 PM
Quik89Si's Avatar
RIP OFF
Yeah, to say the least...especially since my local honda dealer had the MTF for $4.06/qt, and the washers totalled $.86 together...
Alex
Vagitarian
May 14, 2012 09:30 AM
JDM-LuxurySport
May 6, 2010 07:30 AM
JASIYAH6
Mar 9, 2009 10:05 AM
importfanatic17
Jan 8, 2007 01:45 AM
diewX3
Mar 18, 2005 04:18 PM
