car runs for 10 seconds then dies ....
so I was driving my turboed integra the other day and it starts hesitating and then dies and I cant seem to keep it alive u can turn it on runs strong for about 10 seconds then dies also if i try and touch the throttle that kills it to .... I tried changing the map sensor nothing if anyone got any suggestions or clues to why the car is dying it would be much appreciated ... its a 1996 integra gsr thanks for any input Paul....
well i dont think it is the fuel pump cause i can hear it priming strong .... and as far as tps the car with it unplugged does the same thing so that cancels that out because if there was a problem with the tps unplugging it would fix it and the car will just be sluggish cause it would be working with vacuum .... any other suggestions would be much appreciated thanks for all the input ...
sounds like your not gettin enough fuel it possible that the pump isnt pumping fuel like it should or the gas gauge could be wrong and your outta gas .. check fuel rail to see if its getti enough fuel. swap out main relay and check ecu to make sure all connection is good sound stupid but it always thoes things we over look
ok so Its not my fuel puemp its definately getting enough fuel I didnt change my main relay cause I dont have a car to go get parts lol and my ecu is fine I can hook it up to smanager and adjust it from there... anyways let me know thanks ...
Toroke
Jun 9, 2007 06:43 PM
hybridEj6
Oct 4, 2003 03:03 PM
