90mm Piston weight.....Whats the lightest?
Old Jun 8, 2009 | 04:38 PM
EGHATCH4YA209's Avatar
Default 90mm Piston weight.....Whats the lightest?
Interested in hearing the different 90mm piston weights out there and who the manufactor was. Some companys can get them lighter than others but why?
Old Jun 8, 2009 | 07:27 PM
Default Re: 90mm Piston weight.....Whats the lightest?
I know there out there.....................
Old Jun 8, 2009 | 07:31 PM
JDM JEFFREY's Avatar
no more stock piston h22's builds bro?
Old Jun 9, 2009 | 06:19 AM
Not at all. Come on, i know there are guys out there with some light 90mm pistons
Old Jun 9, 2009 | 06:31 AM
2fastGSR's Avatar
King of the One Liners
I'm sure I dont have to tell you this, but Most companys have just one design and add/delete features to it Ie:coating, oil/gas porting . .
To really get the weight down on the pistons you pretty much have to come up with your own design. . You can get most to make you a smaller wristpin, different skirt design thats where the weight comes into play. Now the particulars are way above my knowledge level but thats the basics.
Old Jun 9, 2009 | 08:54 AM
Exactly, Most will run a D series wrist pin, shorten the skirts, and then remove material from the under side of the dome. I've seen however that some company's can get there pistons quite lighter than others, for instance company (A) can get a 90mm piston to weigh 340 grams any lighter will be structurally unsound. But company (B) can get the weight down to 280-300 grams. Do we have any piston specialists out there that can help or possibly add some insight?
Does anyone have a 90mm piston that weighs 280-300 grams?
Old Jun 9, 2009 | 12:18 PM
You mean to tell me no one has 90mm pistons?
Old Jun 9, 2009 | 04:49 PM
mightymaxgst's Avatar
try cross referencing the specs of an oversized turbo eclipse piston. i know the wrist pins are the same.
Old Jun 10, 2009 | 12:26 PM
Jeremyinlinepro's Avatar
I have some 90mm K-series pistons that are 283 grams. They are underhead milled, small domes, super short compression height, and tiny wrist pins. You could probably get some into the 270 range but it is all give and take.
Old Jun 10, 2009 | 12:54 PM
LogicMotorsports.com's Avatar
We ran 90mm custom arias pistons in an all motor car street class car. I have the piston and rod assembled on my desk. As mentioned previously it has the smaller diameter wrist pin and we got some serious internal milling done to shave weight. Sorry I cant be of more help.
deanobob123
Apr 9, 2018 12:16 PM
EGK20A
Mar 28, 2010 12:04 AM
kornkid21792
Oct 3, 2009 10:10 AM
Suck my DX
27
Apr 9, 2007 12:43 PM
