Performer X install
We all know the performer is kinda a pain to install. I am down to one last mod to make everything fit and am wondering if anyone else has had this problem.
The return line on my aftermarket FPR is pinched by the long/fat intake mani's runner. Its not enough clearance to fit the return line on without a really bad kink in the line.
So do i need an aftermarket fuel rail?
A different FPR that will give more clearance?
Anyone that runs this mani, please chime in, I'd like to have the car running soon.
It seems that flipping it 180 would not help since my FPR is equally long on either sides where it attaches.
I'll snap a pic and post it up.
The flash makes it look different than in person. The nipple is about 1 maybe two mm from the runner. Bending It would work if I knew it would not damage the fpr.
I could cut down the nipple and run a longer fuel line, but It would not have a bead roll and I would hate for it to pop off and spray e85 on the header.
It seems to me that there are some honda fuel pressure regulators that have that outlet bent, but im not 100%. If i remember correctly, you can also use D series FPR's, maybe theyre shaped a little differently...
I think I have bent that part before w/o any problems. Id try with an extra one first though, but im preeeetty sure they do have some flex in them...
Have you contacted the manufacturer?
vectorsolid
35
Aug 19, 2013 09:35 PM
