Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
CT-Engineering & Spoon Parts - Hard to find parts in stock and ready to ship!
Old Jun 8, 2009 | 02:25 PM
Flatirons Performance's Avatar
Default CT-Engineering & Spoon Parts - Hard to find parts in stock and ready to ship!
Flatirons Performance is an authorized dealer for both CT-Engineering and Spoon Sports. We do our best to keep a lot of these parts in stock and ready to ship to our customers. Here are a few of the faster moving items, but if you don't see what you are looking for, please check our web-site, or give us a call.
Here is a link to all of the CT-Engineering (aka. Comptech) parts on our site
Here is a link to all of the Spoon Sports parts on our site
Here are some of the more popular CT-Engineering parts that we have:
CT-Engineering Intake for the 2006 - 2009 Civic SI (all models)
- High-Temp Powdercoated Heat Shield
- High-Flow Re-Usable Foam Filter
- Two-Piece CNC Machined and Black Anodized Billet Aluminum Intake Tube
- Designed to limit "Heat-Soak" experienced in other "tube-and-filter" style intakes
- Engineered and Machined to extremely tight tolerances
- Tested to ensure proper operation on CT Supercharged as well as N/A Civic Si
- Dyno Proven 8whp Increase
- Application: 06-09 Civic Si
- Installation time: 1 hour +/-
- CARB legal for street use in CA
The CT-Engineering part number is 320-024
Click Here to order your CT-Engineering Intake for the Civic SI - $242.10
CT-Engineering Civic SI Stainless Steel 4-1 Header (06 - 09 Civic SI)
CT Engineering headers and exhaust systems are manufactured using CNC machined flanges and mandrel bent T-304 stainless steel tubing. All CT-Engineering headers have precision fit merge collectors and all joints are TIG welded for durability and appearance.
CT Engineering uses both its in house DTS engine dyno and Dyno Dynamics chassis dyno to develop all of the headers and exhaust systems we sell.
All CT Engineering headers are 50 state emissions legal.
The CT-Engineering Header for the Civic SI features:
- Full Stainless Steel, Mandrel bent 4-2 header
- TIG-Welded by hand in-house for only the finest quality welds
- We highly recommend pairing with a CT Engineering Cat-Back Exhaust System for maximum Hp gains
- Optimized for high horsepower N/A and Supercharged applications
- 50 State Street Legal, and CARB certified for street use in CA
- Application: 06-09 Honda Civic Si
-The CT-Engineering Part # for this Header is 210-035
Click Here to order your CT-Engineering Civic Si Header - $495.93
CT-Engineering Cat-Back Exhaust for the 2006 - 2009 Civic SI 2-Door Coupe
CT Engineering headers and exhaust systems are manufactured using CNC machined flanges and mandrel bent T-304 stainless steel tubing. All headers have precision fit merge collectors and all joints are TIG welded for durability and appearance. All mufflers are polished stainless steel with a polished stainless steel resonated tip and have been tuned to give a deep aggressive exhaust note, without being too loud.
- Full Stainless Steel, Mandrel bent 2-1/2" Cat-back exhaust system
- Polished Muffler, Polished Resonator, and 4" Polished and Resonated tip
- Smooth, aggressive tone refined for the street
- We highly recommend pairing this system with a CT Engineering Header for maximum Hp gains
- Application: 06-09 Honda Civic Si (Coupe Only)
- Installation time +/- 1 hour
- The CT-Engineering Part # for this exhaust is 230-035
Click Here to order your Ct-Engineering Cat-Back Exhaust for the Civic SI - $651.90
CT-Engineering Rear Sway-Bar for the 2006 - 2009 Civic SI
CT Engineering's 2006 - 2009 Civic Sway-Bar Kit is designed to reduce body roll and improve chassis balance by reducing understeer. CT Engineering sway-bars are manufactured using 6150 aircraft quality steel with a durable powder coated finish.
All CT Engineering Sway-Bar kits come with all required hardware to complete the installation.
- Adjustable rear sway-bar upgrade
- Diameter increased from 17mm (stock) to 19mm
- Two adjustment settings
- First setting is 32% stiffer than stock; second setting is 65% stiffer than stock
- Helps reduce understeer and improves cornering response
- Silver powdercoat finish
- Includes urethane bushings and instructions
- Reuses factory end-links
- Application: 06-09 Honda Civic & Civic SI (not Hybrid)
- Installation time: 1.5 Hours +/-
- The CT-Engineering Part # for this Sway-Bar is 140-035
Click Here to order your CT-Engineering Civic SI Rear Sway-Bar - $139.99
[size=4]CT-Engineering Civic SI Short Shift Kit (06 - 09 Civic SI)[/url]
- Adjusts fore & aft movement
- Reduces shift throws by 22%
- Manufactured from CNC machined from 17-4 Stainless Steel for a precision fit
- Heat Treated to H900 for strength
- Application: 06+ Civic Si
- Installation time: 30 min +/-
- The CT-Engineering Part # for this Short Shift Kit is 560-022
Click Here to order your CT-Engineering Short Shift Kit for the 06+ Civic SI
CT-Engineering Ice-Box INtake for the 2000 - 2005 S2000
The CT-Engineering Icebox Air Intake System is designed to pull inlet air from outside the engine compartment to ensure that denser cold air is actually getting to the engine. Their design also helps keep intake noise to a minimum. The kits use a foam filter that can be cleaned and reused.
All CT-Engineering air intake systems are 50 state emissions legal.
- Cold Air Intake with reusable filter element
- Will not ingest water
- Slightly louder than stock
- Air box suppresses noise from filter element
- CARB legal for street use in California
- CT-Engineering Part # 320-030
Click Here to order your CT-Engineering S2000 Ice-Box - $349.99
CT-Engineering NSX Short-Shift Kit
- Billet Aluminum NSX Short-Shifter
- Ultra lightweight Patent-Pending Design
- Shortens fore/aft, side/side, or both by 25%
- Application: All Acura NSX
- The CT-Engineering Part number for this kit is 560-115
Click Here to order your CT-Engineering NSX Short Shift Kit - $139.99
Default Re: CT-Engineering & Spoon Parts - Hard to find parts in stock and ready to ship!
We have a lot of Spoon parts on hand, and if you don't see what you are looking for on our site, just let us know and we can get it for you.
Here are some of the more popular parts that we stock:
Give your car a unique look with this Spoon Carbon Fiber plug cover.
Made with real Carbon Fiber, not imitation. (Spoon Valve Cover not included)
Click Here to order your Spoon S2000 Carbon Fiber Plug Cover - $155.63
This Carbon Fiber Air duct moves the opening of the air duct lower, and to the front of the car where the air is cooler, and has a higher velocity. This is typically good for an additional 3 to 4 horsepower, and greatly improves the look of the engine bay.
This Part works with the Stock Air-Box and Filter for all 2000 - 2005 S2000's.
The Spoon Part # for this part is 17228-AP1-000
Click Here to order your Spoon S2000 Carbon Fiber Air Duct - $478.99
In contrast to the 88 deg. C start temperature of the OEM thermostat, Spoon's thermostat commences opening at 65 deg. C, and is fully upened at 70 deg. C, substantially improving cooling performance. This is ideal for auto-cross or race applications.
Click Here to order your Spoon Integra/Civic Racing Thermostat - $80.00
Spoon understands that as you increase the power out-put of your engine, this puts additional stress on your drive-train components. From their racing experience, Spoon has found that one of the key areas of the S2000 that needs to be addressed is the rear axle’s.
Using the same process that they use to prep their S2000 Race Car’s, Spoons starts with a factory S2000 Rear axle and improve it by thoroughly polishing all of the bearing surfaces. Once this is done, they reassemble the axle using special high-temp grease. The end result is a dramatic reduction in friction, which keeps the axle’s components cooler, increasing their resistance to wear, and reducing the likelihood of failure.
This is a pair of complete right and left axles, and will fit all 2000 – 2006 S2000’s.
Single axles are available as a special order only, and we strongly recommend replacing both axle’s at the same time.
Click Here to order you Spoon S2000 Axle Set - $1750.00
Spoon designed their rotors specifically for strength and performance under extreem driving conditions both on the street, and at the track.
Spoon's Brake Rotors, are a flap-type cast metal brake rotor, and are cross-drilled for improved cooling in all driving conditions.
Brake rotors are sold as a pair only.
Click Here to order your Spoon S2000 Front Cross Drilled Rotors - $590.00 (per Pair)
Designed specifically to meet Spoon's demanding specifications, Spoon Brake Pads offer the following characteristics:
1) High fade resistance
2) Excellent operation at low temperatures
3) Long lasting
4) Low level of impact to the rotor.
These pads provide excellent stopping power and superior level of control with respect to cornering power, and are essential if you are doing agressive driving, Auto-Cross, or track driving.
Click Here to order your Spoon S2000 Front Brake Pads - $246.56
This Off-Set Ball-Joint kit was designed by Spoon to give you a greater range of camber adjustment in the front suspension of your S2000. By installing these Off-Set Balljoints, you can get up to an additional 2 degrees of negative camber.
This is ideal for cars that are Auto-Crossed, or driven on the track.
The Spoon Part # for this kit is 51230-AP1-000
Click Here to order your Spoon S2000 Off-Set Balljoint Kit - $590.63
Spoon has developed their Engine Torque Damper for the S2000.
The Engine Torque Damper braces the motor to reduce its movement under hard acceleration and engine braking. This puts more torque to the wheels, and gives the car a tighter, more stable feel. This is ideal for aggressive street and track driving, and on higher power engines.
This bolts on with the supplied brackets, and requires no drilling, etc.
Click Here to order your Spoon S2000 Engine Torque Damper - $244.99
Old Jun 8, 2009 | 02:26 PM
Opak Racing took everything they learned building and campaigning the Spoon Race Cars in the US, and have developed their own Titanium Strut Bar for the S2000, and DC5 RSX. This bar is designed to give you the maximum increase in chassis rigidity with the minimum weight penalty.
The entire piece is made of titanium, and weighs in at 32 ounces.
What sets this Strut Bar apart from others is the attention that Opak Racing gave to the mounts. They are gusseted to make them as strong as possible which sets this piece apart from virtually every other Strut Bar.
If you are looking to improve the handling of your car by increasing chassis rigidity, this is a perfect place to start.
Click Here to order your Opak Racing Titanium Strut Tower Brace for the S2000 - 319.99
The Hamp high-performance oil filter is designed to be less restrictive than the OEM oil filter, resulting in better oil pressure for your engine. This is a must on any moderate to highly modified engine.
Fits 1990 – 2001 Acura Integra and 2002+ RSX and 2002+ RSX-S
Click Here to order your Hamp Oil Filter for $12.59
Helps to remove small steel and iron particles from the oil and transmission pan to prevent damage to critical engine and transmission components.
The long plug is for the oil pan, and the short plug is for the transmission. These are pre-drilled for safely wire for racing applications.
Click Here to order your Spoon Magnetic Drain Plug Set - $37.99
Click Here to order your Spoon 5-Speed Shift **** - $58.12
A must have for a Spoon fan. No more blurring out license plate for shoots; magazines, web, etc.
Ideal for car shows and gatherings.
Sold individually in either Blue or Yellow.
Click Here to order your Spoon License Plate Insert - $29.00
Old Jun 9, 2009 | 06:45 AM
Tuesday Bump.
Old Jun 9, 2009 | 02:10 PM
Afternoon bump.
Old Jun 10, 2009 | 08:01 AM
Wednesday bump.
Old Jun 11, 2009 | 10:58 AM
Thursday bump.
Old Jun 15, 2009 | 02:54 PM
Late Monday Bump.
Old Jun 16, 2009 | 06:57 AM
Tuesday bump.
Old Jun 16, 2009 | 02:37 PM
Parts added bump.
Old Jun 17, 2009 | 08:26 AM
Mid Week Bump.
Old Jun 17, 2009 | 02:49 PM
End of the day bump.
Old Jun 18, 2009 | 06:25 AM
Thursday bump.
Old Jun 19, 2009 | 07:23 AM
TGIF bump.
Old Jun 22, 2009 | 10:25 AM
TGIM bump.
Old Jun 23, 2009 | 02:03 PM
Tuesday bump.
Old Jun 24, 2009 | 06:26 AM
Wednesday bump.
Old Jun 25, 2009 | 09:55 AM
Thursday bump.
Old Jun 26, 2009 | 07:04 AM
TGIF bump.
Old Jun 29, 2009 | 10:22 AM
TGIM bump.
Old Jun 30, 2009 | 10:33 AM
Tuesday Bump.
Old Jul 1, 2009 | 12:32 PM
Wednesday bump.
Old Jul 13, 2009 | 08:42 AM
We're excited about the track day we're running on Saturday! Bump!
Old Jul 22, 2009 | 12:54 PM
Wednesday bump.
Old Jul 29, 2009 | 11:37 AM
Next Wednesday Bump
