B16A IN 91' CIVIC STD WONT START (help)
Old Jun 8, 2009 | 01:58 PM
LightWeight(J)'s Avatar
Default B16A IN 91' CIVIC STD WONT START (help)
Haven't been on here in awhile, but I just recently did a b16a swap with some friends in my 91' civic std, and it wont start. The motor isn't getting spark, thus, the motor wont run. It is obvious though that we are getting fuel. We followed the info given to us from MPFI swap on google, and everything seems right. I can't figure out if it is the distributor itself or its the wiring to the distributor. It's all ob0. We used the stock d series harness from my old motor+an ls harness that we used for the plugs and etc. Im running a b16a ECU. We just followed the directions on the MFPI swap site.
If I could get some help that'd be great, cause it is my daily driver, and it needs to start asap.
Old Jun 8, 2009 | 02:02 PM
intense4thgen's Avatar
Default Re: B16A IN 91' CIVIC STD WONT START (help)
if you changed the dizzy plugs make sure the two white wires are in the correct location
Old Jun 8, 2009 | 06:31 PM
bump..need help
DrifterzTX
May 17, 2005 07:56 PM
sanjiyan69
Jun 29, 2004 05:43 PM
conceptEG
May 19, 2003 03:08 PM
driftt
Mar 4, 2003 05:44 PM
ef civic
May 14, 2002 02:53 PM
