rear sway bar question
Old Jun 8, 2009 | 01:54 PM
99jdm_itr's Avatar
Default rear sway bar question
i was just wondering if there is a beter rear sway bar you can put in a itr or is 24 mm the biggest ? if so what else can i do to tighten up the back end of my car
i have lca's and lower tie bar + stock lower bar
Old Jun 8, 2009 | 02:35 PM
SoTexDC2's Avatar
Default Re: rear sway bar question
Are you still on OEM suspension?
Increase the rear spring rates, give them a bias over the front. Choose a swaybar accordingly.
I run GC 350F/450R with Koni Yellows and the OEM ITR swaybar compliments this setup just fine.
Old Jun 8, 2009 | 02:37 PM
Stinkycheezmonky's Avatar
Suspetise...
There are several options for bigger rear sways. Search for "swaybar" or "sway bar" in the ITR or RR/AX subforum and you'll find everything you need. Unless you can give me a reason not to via PM, I'm going to lock this.
VeilSide_Mas
Suspension & Brakes
Apr 24, 2007 12:13 PM
fongph
Apr 15, 2005 10:18 AM
Blown90hatcH
11
Oct 8, 2002 12:59 PM
animated_life
Sep 27, 2002 03:10 PM
