just installed a Neuspeed rear lower tie bar..
but i had to mount it using hardware i bought at Lowe's.. no biggie, just a couple of 10mmx100mm bolts and some 10mm washers..
but the hole in the end link of the tie rod that the bolt goes through is slightly larger in diameter than the bolt. i had purchased the bar new 4 or 5 years ago, but *never* put it on until this weekend, but have since lost half of the hardware.
i think i do remember these spacer/sleeve type things that came with the bar, which i think were meant slip over the bolt to fill that space, but..
should i be okay without those sleeves??
everything seems to be sitting tight and flat with the washers i used, but i am afraid of the bar moving around because of the extra space around the bolt due to the larger-diameter end link..
anyone know what i'm talking about? if so, should i be fine?? i think some members are even doing what i'm doing now..
i just want to be safe! thanks guys
cursED
34
Jun 30, 2003 05:57 PM
91hondacrx
Jun 14, 2002 10:26 AM
