beaks quick swap sway bar kit
I have a 92 DX hatch and I was wondering if this application (EG/DC "quick swap) will work with my car?
I am planning on doing the rear disc conversion in the comming months and I was wondering if the same kit would work on that as well?
I know you guys have used this application befor and I was trying to get a little more info then what the site had to say about it
thanks for all your help
The stock civic arms do not have a mounting point for the "endlinks"...
www.beaksproducts.com
ITRacer - yes it will work on your CX, like mentioned before you will need new lca's and endlinks from a 94+ integra GSR, or 94-95 delsol Vtec application.
enrique - Beaks and BSQ are rear sway bar mounting kits that reinforce the rear subframe. They help reduce the risk of tearouts while using a stiff sway bar such as the ITR bar.
I am using the Beaks set-up with very satisfactory results. I also hear that the BSQ kit works equally well at a bit less cost. I still like my Beaks though....it works and looks good as well.
[Modified by SLPR, 11:59 AM 8/21/2002]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dremmel »</TD></TR><TR><TD CLASS="quote">can u use LCA's and endlinks from a 90-93 teg? or a 92+ civic? </TD></TR></TABLE>
90-93 teg won't work.
As far as i know, the only 92-95 civics with rear sways were the EX sedans. All others have no mounting provisions for endlinks.
Endlinks can be sourced from either the sedans mentioned above, or a 94+ integra.
I have the correct LCA's to mount a swaybar for sale here:
https://honda-tech.com/zerothread?id=671226
broketuner-Sol_Si
May 21, 2006 11:14 PM
AThiker
Jun 16, 2003 03:37 PM
kent, clark
19
Dec 3, 2001 04:21 PM
