Please help Car starts but wont rev
Old Jun 7, 2009 | 10:38 PM
H22_aCCoRd_07's Avatar
Default Please help Car starts but wont rev
cAR IS a 92 honda accord, motor is a obd2 h23a(vtec motor)
It starts and stays at idle but when i pull the throttle it wont rev at all... any advice
Old Jun 7, 2009 | 11:14 PM
Kronn 98SH's Avatar
Default Re: Please help Car starts but wont rev
So you have an Accord with a JDM Accord engine. Yet you posted in the Prelude forum?
Old Jun 7, 2009 | 11:33 PM
because the motor is almost identical to the h22.
Please if you dont have anything smart to say then please keep your immature comments to yourself
Old Jun 8, 2009 | 12:02 AM
GraphiteMW's Avatar
Check the throttle cable,
Try revving it from the throttle body.
Old Jun 8, 2009 | 12:13 AM
Thats what im doing. when i try reving it almost sounds like its miss firing and bogs.
Dizzy is good because it came off my jdm h22 swapped accord
Old Jun 8, 2009 | 12:34 AM
GraphiteMW's Avatar
Check your spark plug wires to make sure it is in correct firing order and wouldn't be a bad idea to check out the ignition timing.
Old Jun 8, 2009 | 12:53 AM
h22 kid's Avatar
lol thats just what i told him graphiteMW
Old Jun 8, 2009 | 12:57 AM
Kronn 98SH's Avatar
Exactly what portion of my post was immature? Keep in mind, you're speaking to an elder.
Old Jun 8, 2009 | 08:42 AM
Ri'can Luder's Avatar
What he meant to say was if you don't have anything constructive to say, don't say anything at all. Hope you fix your Accord soon, wish I could get an H23A engine.
Old Jun 8, 2009 | 09:27 AM
im just going to ignore you because i have bigger problems to deal with, Thanks
Thank you
Im pretty sure i have the correct firing order i have it like this.......
TOP
3 4
1 2
BOTTOM
and checked timing and thats good too
any more ideas???
Old Jun 8, 2009 | 09:52 AM
InvaderTrax's Avatar
When was the last time the car was driven before the swap? If it sat a long time, it may be the fuel pump. Any codes coming up?
Old Jun 8, 2009 | 10:32 AM
Car was driven 3 days ago
codes are ect, iacv, vtec spool...and none of those would make the car do this
I just put in new spark plug wires and spark plugs and its still doing the same thing
Old Jun 8, 2009 | 12:47 PM
slow96lude's Avatar
fuel pressure or injectors would definatly do it too. the pump may be starting to go out. also check the timing belt it may have jumped a tooth or 6
Old Jun 9, 2009 | 12:51 AM
i fixed the problem thanks guys and............. Thank you Mr. elder "Kronn 98SH" for the wonderful useful knowledge and info you provided. You know, its people like you that make others leave HT. Please do everyone a favor and dont give HT a bad rep
Old Jun 9, 2009 | 02:09 AM
Kronn 98SH's Avatar
You're welcome. Because of noobs like you, HondaTech has car-specific areas.
Old Jun 24, 2009 | 05:19 PM
samowen's Avatar
Icon6 Re: Please help Car starts but wont rev
so i'm guessing that when you rev your car it just boggs down and maybe sometime if you ease into the throttle it might work. Here is your problem it sounds like to me that your not getting any signal back from yout tps to your computer it might be a bad tps (throttle position sensor) here is a way you can check get a volt meter and check the voltage at a idle and check it at wide open throttle at a idle you should be getting 0.5 volts. wide open throttle you shoud have aleast 5 volts and do this with the car not running but have the key on in the on position also you can try testing the resistance of the sensor if you don,t get a reading right away try to play around with the wires while you are testing it if you still dont see and numbers but 0.00 then you probaly have a fauilty sensor but make sure when you test for resistance that nothing and i mean nothing is on in the car. My boy's car was doing the same thing and we fixed it this way. good luck to ya man hope this helps you out hit me back if you still have problems peace
nicolas1320
Aug 25, 2010 07:11 PM
H22_aCCoRd_07
Jun 9, 2009 11:05 PM
JDMHatch101
Mar 20, 2005 06:29 PM
95accordh22a
Feb 17, 2005 12:06 PM
nickg11111
Sep 26, 2002 08:31 PM
