weird noise at 3.5k, gsr.
Old Jun 7, 2009 | 09:49 PM
danyal2's Avatar
New User
Default weird noise at 3.5k, gsr.
I'm trying to diagnose a noise that I'm consistantly hearing when my integra is cold, when I hit 3500rpms it makes a whirr sound. It goes away after the car drives for a bit. I checed for loose bolts but I can't find a source. Any help would be appreciated. Thanks!
Old Jun 7, 2009 | 09:58 PM
TOO MUCH TORQUE's Avatar
Default Re: weird noise at 3.5k, gsr.
i dont know your exact problem, but i recommend staying under 3k rpms until the car is nearly warmed up. Engine wear is most apparent when starting a cold engine and running a cold engine hard. So to avoid this noise, keep the car under 3k rpms until it is fully warmed up.
Old Jun 8, 2009 | 07:12 AM
mouab18c1's Avatar
whats it sound like? that would help
Old Jun 8, 2009 | 07:20 AM
abusedvtec's Avatar
does it make the sond when u r driving or parked revving the motor and whats done to the gsr motor
Old Jun 8, 2009 | 11:09 AM
danyal2's Avatar
New User
It seem as it only makes the sound when driving, motor is 100% stock.
Sounds like a metal vibration, should I not worry about it? I drove it this morning keeping it under 3k till it warmed up and had no problems.
Old Jun 8, 2009 | 11:10 AM
MilanoRedDashR's Avatar
Sounds exactly like the sound I have in my gsr. Although mine doesn't go away, It's been doing it for 3 years and never had a problem. Everyone seems to think that its something with my heatshield, so no big deal.
Old Jun 8, 2009 | 12:13 PM
trifenix's Avatar
mine rattles at 3100rpm and i think its the heatshield after the cat converter.
Old Jun 8, 2009 | 12:45 PM
dohcvtak's Avatar
most likely heat shield or header had the same problem end up being the stock header..
Old Jun 8, 2009 | 02:15 PM
Yeah I'm willing to bet its definitely the heat shield.
Old Jun 9, 2009 | 06:41 AM
abusedvtec's Avatar
is it like if u are at 3.5 driving and sitting ther revving cause i have lsvtec and it was a gsr befor motor swap did it before swap its like a horrible rattle but if u go over 4100 it goes away id say heat sheild but all of mine are llready off so id say header mines been doin it for monthes .solution =aftermarket header
Old Jun 9, 2009 | 10:18 AM
Dres's Avatar
sounds like the infamous gsr rattle. Here is the most probable solution.
https://honda-tech.com/forums/acura-integra-6/faq-1994-integra-gsr-pipe-rattle-explanation-how-fix-finally-1795447/
Old Jun 11, 2009 | 07:08 PM
tonys91tegra's Avatar
its the "A"pipe. its the first pipe from ur exhaust manifold to ur cat converter. acura has a bulletin out on that. the bulletin says to replace the "A" pipe. not sure what the warranty is but check it out.
Old Jun 12, 2009 | 07:48 AM
trifenix's Avatar
yea just as well could be. i checked the exhaust heat shield and the heat shield around the cat and they both arent rattling. I wonder if they cover it under warranty...
jacob4lester
Feb 3, 2010 10:14 AM
battosai
Mar 29, 2008 11:32 AM
Babakarab
Jun 30, 2007 04:36 PM
Haruspex
Feb 27, 2007 02:59 PM
redliner8000
Feb 19, 2004 08:49 PM
