all motor JUN cam ???'s
Old Jun 7, 2009 | 06:06 PM
H22hatchin's Avatar
Default all motor JUN cam ???'s
Ok guys heres my setup and for some reason i am only putting down 187whp on a Dynojet. just wondering if you guys see any parts in my build that would conflict with eachother. any opinions would be greatly appreciated.
compression is 250 across the board Running on E85
Head
b18c1 head non ported
Jun3 cams
skunk cam gears
brian crower valvetrain
Supertect std valves
3 angle valve job
Skunk2 intake manifold
BDL 68mm throttle body
block
Ls block Balanced fully
CTR pistons STD size
new rings and hone
i dont know if my CR is to high for jun cams but i didnt think so. 13to1 is the current CR
i was thinking about buying TWM ITB's, do you think my setup would benefit from this? should i try to change my cams out to PRO2's?
Old Jun 8, 2009 | 05:57 AM
J240sx's Avatar
Default Re: all motor JUN cam ???'s
how is your CR 13:1 with CTR pistons?? I personally think your overcamming the motor with the CR that it has.
Old Jun 8, 2009 | 01:50 PM
HAMSTERHONDA's Avatar
what header are you running? also compression is up there, plenty for the cams,,
Old Jun 8, 2009 | 01:59 PM
Clerique's Avatar
https://honda-tech.com/forums/showth...ht=PCT+pistons
According to the information in this thread, you have very high compression and if that is the case, you could benefit from a bigger cam.
Old Jun 8, 2009 | 05:07 PM
H22hatchin's Avatar
compression is some where around 13to1 with a gsr head and ls block according to c speed.
header- Tri y replica big tube
Old Jun 8, 2009 | 05:16 PM
Clerique's Avatar
H22hatchin Check PM
Old Jun 8, 2009 | 06:24 PM
H22hatchin's Avatar
thanks for the offer but i think i am goin to put some itb's on and check the juns out with them.
Mr. EK9
Mar 9, 2011 03:24 PM
96turboteg
10
May 19, 2004 10:42 AM
J2turbo21
Mar 3, 2003 01:21 AM
Mike95lude
Aug 20, 2002 11:31 PM
adamp35
Jul 7, 2001 01:06 AM
