Bleeding ABS Pump Manually
Old Jun 7, 2009 | 04:51 PM
GaRn's Avatar
Default Bleeding ABS Pump Manually
So,
I've had the dreaded ABS light for quite a while and I'm getting ready to sell my car so I'm trying to fix it. I went ahead and bled my brakes today since it has been 2 or 3 years, and I was going to bleed the ABS unit as well.
When I pulled the code a while ago it was the abs modulator unit. So I figured a bleed may fix it as it looks like it is WAY overfilled. I pulled out the ABS relay, opened the bleed nipple, attached my bleed hose, then jumpered the two largest terminals on the fuse box where the relay went.
I hear the pump run, but nothing comes out of the bleed nipple. Something else I'm missing here? Anyone tried this method and have any insight?
Old Jun 8, 2009 | 10:40 AM
GaRn's Avatar
Default Re: Bleeding ABS Pump Manually
up
Old Jun 10, 2009 | 06:22 AM
GaRn's Avatar
Surely others have done this considering every other prelude has this problem.
Old Jun 10, 2009 | 06:39 PM
JJexpress's Avatar
Use a bleeder t-wrench?
Old Jun 11, 2009 | 07:21 AM
catacon's Avatar
Just unscrew the ABS light. Instant fix. :p
But seriously, you may have to use a pressure bleeder to bleed the ABS system. There are lots of different systems and ways to do it. It might be best to take it to a shop, as unpleasant as that my be.
CHiNkStEr
Jul 22, 2011 08:42 AM
Marcg611
Sep 19, 2009 01:14 PM
integ3
Dec 5, 2006 10:06 AM
ShiftDown
Mar 15, 2004 11:08 AM
redDC2
Nov 4, 2002 04:02 PM
