oil pans
Old Jun 7, 2009 | 03:12 PM
Johnny O A20 KIller's Avatar
Default oil pans
Will a newer pan off the 5th gen fit on the 4th gen block? Thanks.
Old Jun 7, 2009 | 03:40 PM
street_ride14's Avatar
Default Re: oil pans
YES .. The 5G aluminum oil-pan will fit a 4G Prelude. 5G uses hondaBond as a sealant, 4G uses rubber gasket. Use proper sealant and you will be fine.
Old Jun 7, 2009 | 04:28 PM
Thanks pal. Did a searc and couldn't find anything. Thanks.
Old Jun 7, 2009 | 05:37 PM
TheJGB3's Avatar
Keep in mind that this is only applicable to H22 (93-96) 4th gens because the F22 motor cannot use an H22 oil pan.
Old Jun 8, 2009 | 12:45 PM
Yes it is for a h22, not a f22. Thanks.
Old Jun 8, 2009 | 02:47 PM
117's Avatar
117
You also will not be able to use the stiffener off of the 4Gen. You'll need to use the 5Gen piece.
Old Jun 8, 2009 | 02:52 PM
vinuneuro's Avatar
Does the 4gen have a stiffener..I thought it was introduced in the 5th?
Old Jun 13, 2009 | 10:50 AM
NirVTEC's Avatar
Be sure you use the dipstick that matches the pan......H22A1 and H22A4 dipsticks are different length.
Old Jun 15, 2009 | 02:26 PM
92civlude's Avatar
What issue of SUPER TUNER magazine did you read that? All USDM H22 dipsticks are the same.
Old Jun 15, 2009 | 05:22 PM
TheJGB3's Avatar
Well I looked up a
1995 SiVTEC part# is
15650-P5M-000 DIPSTICK, OIL $12.31
2000 Type SH part# is
so it looks like they are the same dipstick, I also checked the dipstick tube and they are the same part# too.
2000 Type SH
15200-P13-000 PIPE, OIL LEVEL $12.10
1995 SiVTEC
Old Jun 15, 2009 | 08:50 PM
92civlude's Avatar
Originally Posted by TheJGB3
Well I looked up a
2000 Type SH
1995 SiVTEC
NICE job on the part numbers and prices!
lsjon
Aug 29, 2008 08:34 PM
accrd18
Nov 25, 2006 08:16 PM
EDANSiR
Sep 13, 2006 05:36 PM
2000redsi
Jun 1, 2006 12:00 PM
