Timing on my DA integra. Help!
i got help changing my water pump and timing belt. now my car is running very bad so i think the timing is off can anyone tell me what marks on the crank pully i need to line it up off of to time it.
b18a1 motor
b18a1 motor
If you got all the belts off and the crank pulley of, look at the bottom sprocket, it should have a mark on it. Line up that mark with the little triangular mark thats on the block. The top two timing gears also have marks, they should be at 3 and 9 oclock positions, basically parallel to the head. ------
If any of those are off, then you have to redo the timing belt.
You can also put a flashlight or led light down through through the spark plug holes and turn the crank until the number 1 or 4 piston is at TDC and stays a little motionless
