Buddy Club Cam Gear Degree Marks
Old Jun 7, 2009 | 10:28 AM
eg6madness's Avatar
Default Buddy Club Cam Gear Degree Marks
can seem to find the answer i want...
I wanted to know if the marks on Buddy Club Cam Gears are 1 degree or 2 degrees. since there are only 5 marks on either side of the TDC locator.
if i wanna advance my intake cam 2 degrees do i put it to the first mark ?
Old Jun 9, 2009 | 05:40 AM
eg6madness's Avatar
Default Re: Buddy Club Cam Gear Degree Marks
anyone?
anyone know if they are 1 or 2 degree intervals?
Old Jun 9, 2009 | 07:54 AM
Rocket's Avatar
It might be neither. Measure the distance between the marks. The cam gear is 100mm in dia. You can figure out the circumference by pi*diameter.
Multiply the distance between the marks by 360. If it equals the circumference then each tick is 2 crank degrees ( 1 cam gear degree).
sleeperb16a
Sep 24, 2007 08:12 AM
Gojira D.O.T
Feb 25, 2006 02:34 AM
agent marlon
Nov 21, 2002 11:49 AM
LB CRX
Jul 29, 2002 06:57 AM
