why is there ticking noises from inside the spark plugs?
Old Jun 7, 2009 | 10:18 AM
mynameizstitch's Avatar
Default why is there ticking noises from inside the spark plugs?
just put in a new longblock b18b1 and i hear ticking noise from the spark plug hole nearest to the distributor and very slight ticking from the furthest to the right of the distributor. why is it doing that? its louder if i press in a little on the spark plug wires. also when i would touch the spark plugs to the distributor i would get shock also. so what are the causes for this? the thing is the car runs perfect tho. just want to know what is wrong before something major comes up
Old Jun 7, 2009 | 10:24 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: why is there ticking noises from inside the spark plugs?
From what I gather it sounds like you are getting some arching. Have you changed the wires lately?
Old Jun 7, 2009 | 10:28 AM
arching??? never heard of that haha. i used the old spark plugs that were in the motor before. b18a1 motor was the motor in it before
Old Jun 8, 2009 | 07:30 AM
anyone???
Old Jun 8, 2009 | 01:04 PM
91akira's Avatar
Originally Posted by mynameizstitch
anyone???
Funny you posted this. I had recently swapped my Magnacor wires for OEM Blue NGK wires. At first I got those ticking noises too. It went away after a couple of days of driving. wierd.
Yours might go away too. Let us know.
Old Jun 8, 2009 | 01:09 PM
KingKnight's Avatar
So true.
Old Jun 8, 2009 | 02:26 PM
so its eventually going to just go away?
Old Jun 8, 2009 | 02:36 PM
91akira's Avatar
Not sure. Just wait couple days.
Could be that your spark plugs are loose? Torque them to spec. Try that.
Old Jun 8, 2009 | 03:45 PM
TOO MUCH TORQUE's Avatar
remove the distributor cap and check to see if there is powder inside the housing. if so this could be why it is ticking and it also means the dizzy's bearing is starting to go.
could also be loose valves, check them
Old Jun 8, 2009 | 07:40 PM
hopefully its not loose valves!!!
Old Jun 8, 2009 | 11:08 PM
^ hope it is, because that is an easy and free fix
Old Jun 9, 2009 | 08:27 AM
blakcoupe09's Avatar
it sounds like arching to me to
Old Jun 9, 2009 | 10:18 AM
what is arching????
Old Jun 9, 2009 | 10:50 AM
its when the spark is hitting on somthing other then the spark plug..like if the plug wire or boot came off of the spark plug
Old Jun 9, 2009 | 11:31 AM
qpDA9tegqp's Avatar
New User
ahh i ithink mine is arching then cuz i got the same thing but on 2 of my spark plugs im missing the bottom
Old Jun 10, 2009 | 05:46 AM
91akira's Avatar
what is arching????
Update? Still making noises?
Old Jun 10, 2009 | 06:22 AM
dntnedvtec's Avatar
Do a tune up. Change your dizzy cap, rotor in side the cap. and plugs. Maybe wires also. If its still there, I agree with TOO MUCH TORQUE, ticking valves.
Old Jun 10, 2009 | 07:17 AM
sorry no updates yet. my wife daily drives the car i will check up on this this weekend
mynameizstitch
Jun 8, 2009 07:29 AM
ty_uni_ek08
Oct 14, 2008 12:46 PM
SonicBluDC2
Mar 30, 2007 08:12 AM
b16b18
Sep 6, 2006 12:56 PM
EblazeK
Aug 4, 2006 01:02 PM
