motor mount broken??
Old Jun 7, 2009 | 08:46 AM
98civtec's Avatar
Default motor mount broken??
if i had to guess i would say that opne of motor mounts is broken, beacause when i give it some gas the shifter seems to move back about an inch what could this be opinions?
Old Jun 7, 2009 | 09:33 AM
98civdx's Avatar
Master Detailer
Default Re: motor mount broken??
try tighting the motor mount bolts they may be loose.
my buddys integra did this and i found the bolt was almost all the way out.
if that doesnt do it look at motor mounts.
Old Jun 7, 2009 | 11:15 AM
SeanZ0r's Avatar
check your motor mounts, Trans, drivers side, and rear
Old Jun 7, 2009 | 11:19 AM
Former User's Avatar
Inspect all of the mounts:
Old Jun 7, 2009 | 11:20 AM
Pothole987's Avatar
Definetely check your rear engine mount. most likely the culprit.
Old Jun 7, 2009 | 11:45 AM
yoontim23's Avatar
Check all your mounts and bolt's if any of them are loose or torn replace or tighten them.
Old Jun 7, 2009 | 12:28 PM
98civtec's Avatar
alright it almost seems like when i shift from first to seocond the motor kicks back quite a bit it feels kinds a jerky even when its a good shift so would that be the rear motor mount most likley
Old Jun 7, 2009 | 01:26 PM
thumper64's Avatar
You don't have to replace your mounts, I'm amazed nobody has mentioned Window Weld yet. $10 for a tube at Autozone, Farm&Fleet and various other places and it should do multiple mounts.
Old Jun 7, 2009 | 05:20 PM
SeanZ0r's Avatar
http://www.realhomemadeturbo.com/for...e&topic=2098.0
Even better, and only costs 2 dollars a mount : )
civicsi18
Oct 27, 2008 12:05 PM
Novtecdohc
Jun 24, 2005 01:16 PM
rocketfuelcerx
Apr 8, 2005 11:53 AM
Maengelito
16
Dec 5, 2004 07:07 AM
JUN JDM
Jul 13, 2003 08:11 PM
