wire tucked my new motor...
Old Jun 7, 2009 | 08:17 AM
420EKallDAY209's Avatar
Default wire tucked my new motor...
just to see what you guys think about my first time swappin a motor. and i thought i might as well wire tuck and wax the engine bay while the motor is still out of my car....
any other suggestions on makin it look better?
Old Jun 7, 2009 | 08:28 AM
JDMdew's Avatar
Default Re: wire tucked my new motor...
fill all of the unused holes.
Old Jun 7, 2009 | 08:29 AM
yea i was think in about that? but with what?
Old Jun 7, 2009 | 09:00 AM
DCRB's Avatar
spot weld them. also, go to the j/y and get a throttle cable from an integra or a civic that is mpfi. just know that the auto cables and manual cables have different
Old Jun 7, 2009 | 12:31 PM
Smokinsax's Avatar
The Boot
use some nice hardware (washers/bolts). It would add so much.
Old Jun 7, 2009 | 12:40 PM
alx_90ef's Avatar
nice tuck.
but weak engine?
why didnt you do a swap?
Old Jun 7, 2009 | 01:02 PM
jhhj332007's Avatar
LOOKS GOOD
Old Jun 7, 2009 | 01:15 PM
antigram's Avatar
tuck the brake lines
Old Jun 7, 2009 | 01:25 PM
DOHCED8's Avatar
run the brake booster hose under the MC
Old Jun 7, 2009 | 01:40 PM
4DRmafia's Avatar
Originally Posted by alx_90ef
nice tuck.
but weak engine?
A6 is not a weak engine.
Old Jun 7, 2009 | 01:44 PM
es.roadster's Avatar
a6 is a great motor.
Old Jun 7, 2009 | 02:05 PM
xthekidx's Avatar
just get yourself a lil turbo kit for that thing and you will make a monster out of a stock a6.
seen it done.
i do wire tucks and that looks awesome. good job.
one thing ill add is to run the clutch cable underneath the IM.
Old Jun 7, 2009 | 02:26 PM
DOHCED8's Avatar
seen it done.
good eye on that one. i didnt even notice the clutch cable.. that would be a good thing to do
Old Jun 7, 2009 | 02:39 PM
CRX-Kid11's Avatar
I think it looks great. Wanna do mine?
Old Jun 7, 2009 | 02:43 PM
DOHCED8's Avatar
i think your coolant hoses are in the wrong spot as well
Old Jun 7, 2009 | 02:44 PM
TypeRMOBBiN209's Avatar
very nice for first time
vtechjunkie's Avatar
x2 on the holes!
Old Jun 7, 2009 | 03:54 PM
hai_tech's Avatar
look good
Old Jun 7, 2009 | 04:46 PM
EJ1_Sleeper's Avatar
ok...so you have a throttle cable running across your motor to where? whats with the cable in the front running parallel with the rad?
why does your rad hose look just way wrong?
your brake booster hose is 1/2 connected (flip the booster to tuck it).
tuck your clutch cable behind your manifold
turn the wires on your brake reservoir behind it so its not visible.
Old Jun 7, 2009 | 06:37 PM
yea its not all done yet... i still got to do a day of work to finish everything.. im just waiting for my day off on thursday to finish it... still need to get the last things i need at pick n pull...
Old Jun 7, 2009 | 07:35 PM
DCRB's Avatar
my guess on his rad. hoses is that they are looped so hidden coolant wouldn't leak all over?
Old Jun 7, 2009 | 07:37 PM
ykni's Avatar
what does it cost to get wire tucking done if you pay ? is it expensive ?
Old Jun 7, 2009 | 08:40 PM
around 200 right?
Old Jun 7, 2009 | 09:10 PM
gsrauto98's Avatar
definitely looks good for a first timer
Old Jun 7, 2009 | 09:14 PM
Looks great man. im planing on doing this for my hatch but not for awhile.
