NEWBEE NEEDS HELP IN ORLANDO !
MY DAILY DRIVER IS ACTING UP AND I AM LOOKING FOR SOMEONE IN THE ORLANDO AREA WITH MORE MECHANICAL KNOWLEDGE THAN ME THAT MIGHT BE ABLE TO HELP ME TROUBLE SHOOT AND REPAIR WHAT AILS MY 95 CIVIC EX.
CURRENTLY IT IS NOT STARTING AND IT GIVES SORT OF A SEMI ELECTRICAL HUM WHEN I TRY TO START IT.
IT ALSO HAS AN OIL LEAK. i NEED TO GET THIS CAR BACK ON THE ROAD ASAP AS IT IS MY DAILY DRIVER. aNY LOCAL HELP WOULD BE GREATLY APPRECIATED.
tONY
tONY
Sounds kinda like a bad starter. Either that or you're not getting spark, likely due to a bad ignition coil.
When you turn the key to on (before you turn it to start), does the check engine light turn on for a few seconds and turn back off? At that moment, you should also hear the fuel pump make a humming noise... this indicates the fuel pump is priming. Is that the humming noise you are talking about?
Ok car attempts to crank, but does not start.
Tested distributor, and ICM,... both good. Pulled fuel rail, injectors working,...so what next ?
Yes the check engine light comes on BTW, when you turn on the key. Fuses OK.
Seems like an ignition problem of some sort.
Took the car to a shop and they said the engine has virtually no compression.
However a friend who took a look at it previously said he did not think the engine was toast.
dont belive **** that shops say. Especially in the economic time were in now. They will rip you off even harder. Buy a compression tester at a local autoparts store and test it yourself.
Talked to the mechanic again and he says he did indeed checking the timing and it was good.
The compression numbers he gave me were 35-55 dry, and around 120 wet.
I believe it should be up around 135 or so ?
They weren't really trying to shake me down either, IMO (like pushing me to fix or do an engine swap), they seemed more like this car's time has come.
You can put another D16Z6 in that car for like $300. (well, if you do it yourself... getting a shop to do it should be all that outrageous though, it's a direct replacement swap).
You'd just need the engine, since you can reuse anything else.
Reaper369
Jul 1, 2007 09:25 PM
jaydm ferio
Dec 8, 2006 11:27 PM
civicturbo22
Jan 25, 2005 05:43 AM
Spooled1.6L
Apr 20, 2004 05:49 AM
