Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hard to get in and out of reverse???
Old Jun 6, 2009 | 07:14 PM
8_UR_AWD's Avatar
Default Hard to get in and out of reverse???
Well I have a 99 civic SI and it is really hard to get in and out of reveres and fith gear grinds at high rpm's. Does anybody have an idea of what is the cause? could a simple change of tranny fluid fix the problem?
Old Jun 6, 2009 | 07:40 PM
stevenDAtegra's Avatar
Default Re: Hard to get in and out of reverse???
I'd try changing the fluid first, 2.2 quarts.
Old Jun 6, 2009 | 08:40 PM
8_UR_AWD's Avatar
Thanks
If it makes a diffrence it does this wether the car is on or off.
Old Jun 6, 2009 | 09:07 PM
Well then I think that takes the clutch and throwout bearing out of the issue. Fluid sounds like the best bet to me.
Old Jun 7, 2009 | 09:32 AM
8_UR_AWD's Avatar
Thanks bro!
Anybody else have input on this?
Old Jun 8, 2009 | 04:21 PM
91tegraRS's Avatar
could be something worn inside but changing the fluid is the first and easiest thing to try without pulling the trans and opening her up
Old Jun 9, 2009 | 09:41 AM
Evs-One's Avatar
Solbros Owns Me
Could be a problem in the 5-R sleeve or hub...if you're grinding into 5th and have issues with reverse, you may have materiel lodged in the slider or a broken spring. Could be a fluid issue also
HA0589
Mar 7, 2014 09:09 PM
deerman2701
12
Sep 6, 2013 03:11 AM
selfmade0086
Jun 3, 2013 07:12 PM
bigsnorlax
Oct 30, 2008 05:11 PM
thepoplin
Nov 11, 2004 02:36 PM
