Suspension & Brakes Theory, alignment, spring rates....
Need some help, Brake Caliper Piston Stuck
Old Jun 6, 2009 | 06:38 PM
talkJDM's Avatar
Icon6 Need some help, Brake Caliper Piston Stuck
Nevermind ...
Old Jun 7, 2009 | 01:25 AM
jasoncanseeoh's Avatar
Default Re: Need some help, Brake Caliper Piston Stuck
How'd you fix it?
Old Jun 7, 2009 | 08:15 PM
talkJDM's Avatar
It wasnt stuck to begin with.
I had completely forgotten that you cannot compress Rear Discs Brake Pistons, they are threaded.
Old Jun 7, 2009 | 08:35 PM
When you change the front pads/rotors, do you have to compress those then rebleed?
Old Jun 7, 2009 | 08:52 PM
talkJDM's Avatar
You have to Compress the Front Brake Pistons to place the New Pads in there, yes. Just use a Big C-Clamp for those or the Brake Piston Compressor Tool. No need to bleed the system for changing just the brake pads and Rotors unless of course you got Air in the lines some how by disconnecting them. You can also rebleed if you feel the pedal is not as firm as it should be after the rotor/pad change.
Old Jun 7, 2009 | 09:06 PM
Thanks, bro.
Old Jun 7, 2009 | 09:20 PM
talkJDM's Avatar
Originally Posted by jasoncanseeoh
Thanks, bro.
No problem
Old Feb 8, 2010 | 06:14 AM
bwstryker's Avatar
New User
how do you compress the rear pistons? i have to tool but none of the adapters fit what can i do?
Old Feb 8, 2010 | 08:36 AM
talkJDM's Avatar
Wow, BUMP from the dead that wasn't even necessary if you would've read the entire thread ...
... you cannot compress Rear Discs Brake Pistons, they are threaded.
That being said, your screw them in to compress them.
cyco
Honda Motorcycles
Jun 2, 2009 08:11 AM
dr_spock
Honda Civic (2001 - 2005)
Sep 20, 2008 10:22 PM
datssoled
Jul 12, 2007 07:25 PM
DaKINE-Ek
May 22, 2004 02:40 PM
NtegraRacR05
Nov 28, 2003 09:37 PM
