JDM h22 swap not starting
Old Jun 6, 2009 | 06:17 PM
MJT805's Avatar
Icon2 JDM h22 swap not starting
Im trying to start my h22 but it wont turn over. I swapped in a jdm h22 for a h23 and everything is connected, starter works and motor tries to start but wont turn over. the motor came from a shop that steam cleans their engines and when i took off the dizzy some water came out.
could it be that water is affecting the spark?
also i used a 30amp blade fuse to ground out my external ignition coil cuz the jdm h22 has internal one... any help is appreciated.
Old Jun 6, 2009 | 11:36 PM
ArmaanOG's Avatar
Default Re: JDM h22 swap not starting
get a new dizzy your ***** fried
Old Jun 7, 2009 | 04:22 PM
vinuneuro's Avatar
Check if you're getting spark and fuel. Also check cam timing.
Old Jun 7, 2009 | 04:39 PM
MJT805's Avatar
i'm getting fuel, but no spark. i dont know how to check cam timing. any info i could get on that would be great.
Old Jun 7, 2009 | 08:38 PM
ArmaanOG's Avatar
if your not getting spark check all your grounds, battery etc... most likely your dizzy
Old Jun 7, 2009 | 08:39 PM
genki619's Avatar
Something similar happened to my jdm h22a swap. It turned out to be the internal coil in the distributor. You can test to see if its good using a multimeter. The test is in the helms manual. My secondary coil was reading 11 ohms and the spec said 14-22 ohms. I changed the coil and she fired right up. You can buy a new one at autozone for $75 made by duralast if you test yours and its out of spec. Oh yeah, if you go to the local parts store, you have to ask for 2001 civic SI distributor stuff, like cap, rotor and coil.
Old Jun 8, 2009 | 07:47 AM
MJT805's Avatar
I replaced my whole distributor. i bought the h23 dist., new cap, new rotor, and i'm using my external ignition setup like the h23 was. you think i should have bought a dist. for a 2001 civic si? i'm going to start a new thread explaining my setup
Last edited by MJT805; Jun 8, 2009 at 08:04 AM. Reason: added in a little extra info
Old Jun 8, 2009 | 08:04 AM
ArmaanOG's Avatar
should be fine
Old Jun 8, 2009 | 10:08 AM
MJT805's Avatar
Is a jdm h22 made in 1995 obdI or obdII?
Old Jun 8, 2009 | 11:15 AM
red92si's Avatar
Should be OBD-I
brian8702
Aug 19, 2010 06:43 PM
dsmcoco
10
Mar 24, 2008 03:31 AM
cheezoto
Dec 27, 2004 10:33 PM
misledyouth
Mar 9, 2003 06:45 PM
