4speed to 5speed 4gen civic
Old Aug 20, 2002 | 04:08 AM
JStone2775's Avatar
Default 4speed to 5speed 4gen civic
I'm doing a Si motor swap in my STD 91 Honda Civic, and I have all of the parts I need for the motor swap, but I'm doing the Si tranny also. My Q is will everything must swap out 4speed to 5speed. I don't need to change any linkage or anything do I?
Old Aug 20, 2002 | 04:48 AM
markedOO1's Avatar
Default Re: 4speed to 5speed 4gen civic (JStone2775)
nope..you should be good..just make sure you use your stock axles...the si axles wont fit in your hubs... (I'm assuming std hubs are the same as hf)..
Old Aug 20, 2002 | 08:27 AM
guttedEF's Avatar
Default Re: 4speed to 5speed 4gen civic (marked001)
Yeh, the STD 4-speed hubs are too small to fit the Si axles. If you can, should go ahead and change to the Si hubs too, then you're all set for a B-series swap one day..
Old Aug 20, 2002 | 09:04 AM
d357r0y's Avatar
true SI axles wont work with the STD hubs.. but i believe the STD axles will work with the SI tranny.
Old Aug 20, 2002 | 11:16 AM
Urban Business
Guest
Posts: n/a
Default Re: 4speed to 5speed 4gen civic (d357r0y)
yeppers i have std axles/hubs still. tranny side is all the same hub side is different
TougeCoupe
12
Jan 15, 2010 05:06 PM
LurkerS8
17
Jun 25, 2005 07:46 AM
gutted-dx
Mar 4, 2005 10:04 AM
sabertooth
Apr 22, 2003 04:18 AM
djsgtrip
Apr 16, 2003 04:09 PM
