D16Y8 Head Gasket Job Questions
Old Jun 6, 2009 | 11:51 AM
thi3v3z's Avatar
Default D16Y8 Head Gasket Job Questions
Ok, to start er off. Like a dumba$$, i was doing the valve seals, and trying to keep the head on, and well needless to say, i dropped a valve in the cylinder by accident. Horray for me. So now i gotta pull the head, and imma replace the head gasket and bolts. My questions to all of you is what else should i replace while doing this job??? Cam Seals?? the timing belt and H20 pumped were changed 20k miles ago. Ill need a Intake Mani gasket, im trying to make a list for the parts store. Should i have the head machined while its off. Any Help is appreciated
Old Jun 18, 2009 | 04:04 AM
primerpimpin's Avatar
Default Re: D16Y8 Head Gasket Job Questions
bump, i need to know also!!!!
Old Jun 18, 2009 | 10:33 AM
d16y8turbo's Avatar
i usually just get coolant, oil, oil filter, head bolts/head studs, IM gasket, and the head gasket.
you dont need the head resurfaced, but i would take it to a machine shop to make sure it doesn't need to be resurfaced. most shops wont charge just to check if it's flat.
Old Jun 19, 2009 | 06:50 AM
WHOIZDIZGUY's Avatar
how much u spend while doin all that???
Old Jun 19, 2009 | 06:52 AM
and is thr a link u hav with proper instructions on changing the head gasket on this motor
Specail Ed
Nov 20, 2009 07:09 AM
austincrx
Sep 7, 2006 09:49 AM
