CRX B17a1 Won't Start Sometimes
Ok 91 CRX B17a1 Rywire engien harness and obd-obd1 jumper harness.
Here's the problem Swapped Intake Manifold,Throttle Body over the weekend and 3 days later the car wouldn't start and i didn't hear the relay clicking or the fuel pump coming on, So i took my other car to work. Now i cam home after 6pm and tried starting the car and it started with alittle help from the gas pedel i heard the relay and fuel pump.That night i drove it and it started and ran fine. Next morning i jumped in and it didnt want to start again the engine turns over fine, but the relay and fuel didnt make a sound. I know main relay tried 1 new and 2 used ones same thing, now here is what i tried i jumped the fuel pump yel/blk wire with 12v and the fuel pump turn on and then the car started.Then i tried with just the key and nothing. I wiggle each wire one at a time and when i wiggled the BLK it the relay clicked.So fine the i figured if it did start just wiggle the wires. But i dont want to do that all the time so i am asking for some help if anyone has had this problem to chime in. I have put a whole pack of Dielectric grease in there and the car has been starting for a couple of days with out a problem until to day. I know a ground comes off the ecu and a couple of wires as well to the main relay but i dont know if one has to do with the other please is anyone has had this problem open to idea's.It's a stock ecu for the
B17 engine.Also i dont think swapping the intake and throttle body would cause this problem.
Thanks in advance Hope somebody can help
grkblood13
Aug 28, 2008 04:22 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
