d15b swap
Old Jun 6, 2009 | 08:43 AM
bpatterson6003's Avatar
New User
Default d15b swap
I did a D15b in a 93 dx. Swaps runs good but is tripping a code for the 02 sensor. I had to use the four wire O2 sensor because the 1 wire O2 sensor would not plug into the harness. I am running a P08 ECU. If I run a P28 would this solve the problem.
Old Jun 6, 2009 | 09:43 AM
b20eghatch's Avatar
Default Re: d15b swap
it should fix the problem to run the p28 ecu
jackhunt321
Oct 3, 2006 05:39 PM
StreetEG
Mar 28, 2005 10:20 AM
trooper0641
34
Apr 23, 2004 12:29 PM
JBk24crx
Oct 22, 2003 07:57 PM
