Check Engine Light
Once my Lude gets to 45 MPH my check engine light turns on....what might be causing this to trigger the light?
Need to know what the check engine light is in order to be able to help you. Take it to a local auto parts store and they should be able to pull it for you for free, or you can search in the faq's and pull the code by jumping the 2P connector for it. My first guess would be EGR code though, as that triggers only above there somewhere. What's your mileage?
I found this well-written answer. Someone spent some time making it.
https://honda-tech.com/forums/showth...7#post38252637
Joshboom2488
11
Jul 27, 2014 05:50 AM
