ITR Mainshaft? need a new one questions and How to tell usdm from jdm?
Old Jun 5, 2009 | 08:43 PM
80 dolla crx hf's Avatar
Default ITR Mainshaft? need a new one questions and How to tell usdm from jdm?
Mine is bad one of the teeth are gone. Can i use a gsr trans and just switch the lsd and be done or can i use the gsr mainshaft?
Do i need just the ls 5th gear and syncro to install it so i have a higher 5th?
I know its a lsd trans thats easy but how do i tell if its jdm or usdm?
It had j4d lsd stamped on it and it says s80 and some number after that on the case... How do i tell if the final drive? On both the case and lsd/internals? As before i bought it it was pulled apart?
pretty sure j4d is jdm only.
Just wanna make sure which fd it is and what parts i can use to fix it
Thanks for your help.
Old Jun 6, 2009 | 01:40 AM
Clerique's Avatar
Default Re: ITR Mainshaft? need a new one questions and How to tell usdm from jdm?
Wrong forum!!!
But...
No Difference!
Gears suck and mainshaft carries 2nd gear, so No!
[b/]Just the main and countershaft gears alone[/b]
JDM has no metal badge attached (Could have been removed though)
Do a search for gear ratios and start counting teeth
Old Jun 6, 2009 | 09:59 AM
Hows this the wrong forum its a itr trans in in itr teg in the itr forums? Thats my questions
Old Jun 6, 2009 | 10:05 AM
The teeth where it meets the diff are sheered off
Old Jun 6, 2009 | 10:28 AM
racebum's Avatar
don't quote me but i THINK the main shafts are the same. you really don't want a gsr box on an itr even with the lsd. the 1-2 shift will **** you off. post this in the transmission forum, a couple really smart guys post in there and can get this figured out for you.
80 dolla crx hf
Transmission & Drivetrain
13
Jun 16, 2009 07:44 AM
DJ Gurgla GSR
Jul 3, 2006 12:23 PM
RACING INTEGRATION
Sep 21, 2005 05:54 PM
JDM CRX
Feb 3, 2003 07:40 PM
