hyrdo clutch line help!
i am building a del sol with a gsr motor and b16 tranny. the part that i really need help with is the clutch line. i wanna run steel braided hose if possible but not sure on how to make it work or if special fittings are needed?
Not that I know of. Why, may I ask? For the look? The lines from the master cylinder that runs along the firewall should already be metal. Can't get much better than that. There's only a small section of the line that is made of rubber. The SS line above replaces that rubber line to make it metal all the way through to the slave.
i bought a single line that goes from my master to slave cylinder. it runs over the tranny and on top of the intake mani. theres a vendor in the marketplace that sells them
So, after spending all the time, effort, money, and parts to make your car run don't run cheap soft-lines for the clutch or brakes.
Keep in mind that you can have 3 of the following:
1. Cheap
2. Powerful/Effective
3. Reliable
You can't have it all.
