d16z6 motor into an 88 crx si
what up guys and gals.
im ganna be doing this complete swap over on my car.
so far what i got is a mini me in it right now z6 head on a6 block with a6 manifolds.
my question is and trust me ive tried searching and i dont find and good info or what id like to hear.
what mounts do i need, can i use my stock ones?
for the hydro tranny can i just use an eg brake booster and master cylinders and just permanatly convert it to hydro?
can i use my stock axels?
is the wiring the same on the tps, map ect......?
please help.
thnx in advance
please help.
thnx in advance
You can use your stock mounts and linkage. Use a cable trans unless you get the Sonem bolt in hydro clutch conversion. https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/sonem-ef-bolt-hydraulic-clutch-conversion-2472947/
The wiring is the same as the z6, if your z6 is running properly, then you shouldn't have any issues.
