5 lug conversion
Cool Cool Island Breezes. BOY-EE
The CR-V spindle should fit. You might need an alignment afterwards. You will need 36mm axles. You might be able to just use the CR-V axles all together. If not, you can get JDM ITR 36mm axles (expensive) or you can take prelude/accord/cr-v outer joints and mate them to your axles.
The CR-V spindle comes with ITR sized brake calipers/rotors. I think it's basically a 96-00 EX/SI spindle with a JDM ITR hub and brakes on it.
What are you going to do about the rears?
SPOONfdEK
15
Apr 1, 2005 03:39 AM
