Valve adjustment on ZC engine
Hi All,
New to posting, and I have search on this topic as well. So I have a 93 DX with a ZC engine.
On the head, I have on the left side (exhaust) PM3-13 and next to it says 9/4 (1994 year of production). The right exhaust side says (circle) 2/9.
Under the hood, it says .24 IN & .25 EX.
So my questions is, does any one know if the valve clearance sounds right? I have been doing some research and I am not sure if the previous owner swap in a JDM engine or not.
I have a feeling my clicking sound is a heads up for me to adjust my valves.
Problem: On idle, it sounds normal. And even when I rev it during the car is parked, it is normal. But when I start to drive it, I can hear a small clicking sound. It gets louder when I go up hill. Oil is not low and I double check that before assume other areas.
Any help on what it maybe? Thank you!
Note:
on the dizzy cap, there are two grey harness. Will this be an OBD1? or is it and OBD2?
Note:
You may want to ask this question over on d-series.org
Have you checked the stickys at the top of the forums here ? like the tech/misc forum. Or the new red sticky on all forums.
.24 could mean a mm measurement. I believe most Honda's run .009 exhaust and .007 intake.
I alway's check the book first.
civicboy420
33
Jan 13, 2013 02:03 PM
ScottEK
Oct 19, 2002 11:23 AM
