lca help... confused....
Old Jun 4, 2009 | 07:01 PM
se_hatchback's Avatar
Icon2 lca help... confused....
well today i threw some lca's on and as i put them on i decided to lower it an inch
more.... well when i got done with the car, it sat as it did before i even started... has anyone ever ran into this problem before or anything similar? im so confused....
Old Jun 5, 2009 | 08:31 AM
Default Re: lca help... confused....
anyone think it might be the lca's?
Old Jun 5, 2009 | 09:07 AM
lpparker97ls's Avatar
i could be that it hasent settled yet. give it a few days
Old Jun 5, 2009 | 09:35 AM
JDM 98 GSR's Avatar
drive it around for a little bit. everything should settle then you will see the difference
Old Jun 5, 2009 | 09:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Did you by any chance leave the LCA bolts loose until the suspension was loaded, and then tighten them up? That's how you're supposed to do it.
If you can't get under the car with the car's weight on the suspension, then place a jack under the LCA and raise it up until the corner of the car just barely lifts off the jack stand. Then tighten the bolts to spec, any bolt that passes through a bushing in the LCA.
Old Jun 5, 2009 | 09:47 AM
cpl rampage's Avatar
also, is the spring still in the correct locations in the perches, ie it didnt twist or move sideways?
Old Jun 5, 2009 | 10:11 AM
jasoncanseeoh's Avatar
OR it could be sitting differently, but you just can't notice it.
Old Jun 5, 2009 | 01:33 PM
thanks for every1s advice.... ill try it again forth fourth time lol...
Old Jun 5, 2009 | 01:35 PM
did not know this.... great to know...
thanks...
dgmorr
12
Sep 22, 2005 01:41 AM
EJ20
May 27, 2005 12:16 PM
Lil Corb
Sep 5, 2004 06:30 AM
.jacob
Jul 21, 2003 08:44 PM
2000fbp
11
Jul 10, 2003 10:42 PM
