flashing CEL
Old Jun 4, 2009 | 03:21 PM
Nate13's Avatar
Default flashing CEL
hey,
I don't have a code reader and my CEL flashes for 10 seconds when i start the car (2002 EP3) then goes off for the rest of the ride. All i have on the car is a head unit (not the problem) and a used injen CAI with password:JDM filter (probably has something to do with it) if anyone knows what this could be that'd be great otherwise i'll have to find a code reader somewhere or just finally fork over the $ for one.
thanks in advance
-Nate
Old Jun 4, 2009 | 03:44 PM
02_Si_FTW's Avatar
Default Re: flashing CEL
just a standard light that comes on at a certain mileage. Maybe 90k? i think that was mine. Hold down the button on your speedo for about 10 seconds i think.
Old Jun 4, 2009 | 07:00 PM
Nate13's Avatar
ill try that tomorrow, its at 112k tho? :/
Old Jun 4, 2009 | 07:54 PM
Targa250R's Avatar
be professional
That's not the Check Engine light. It's the Maintenance Required light. Two very different things.
The Check Engine light indicates an emissions control system problem. The Maintenance Required light is just a mileage ticker that comes on every 7500 miles or so to remind you of services.
To reset the Maint. Req.'d light, turn the car off completely. Press and hold the odometer select/reset button with one hand. While holding the button, turn the key to "on" (position II). Continue to hold the button while the Maintenance light blinks (or stays on solid, depending on status). After about 8 seconds or so, it will turn off. It has now been reset. You can let go of the button and go about your business.
Old Jun 5, 2009 | 06:51 AM
Nate13's Avatar
thanks man
8_UR_AWD
Honda Civic (2001 - 2005)
13
Mar 8, 2009 06:19 PM
SiTR
Feb 14, 2008 04:19 PM
m2s4drespecial
Oct 5, 2007 06:42 PM
JDM-EJ1
Apr 5, 2005 11:55 AM
Nikoli
May 3, 2004 11:59 AM
