HTH do i get my gauge cluster out?
Old Aug 19, 2002 | 09:23 PM
89 CRX SI's Avatar
Default HTH do i get my gauge cluster out?
im putting in some gauge faces and i need to get it out. how do i do this?
Old Aug 19, 2002 | 09:53 PM
Louie B.'s Avatar
Default Re: HTH do i get my gauge cluster out? (89 CRX SI)
http://groups.msn.com/Thumpu77sphotos/guageswap.msnw
Old Aug 19, 2002 | 10:41 PM
tysf's Avatar
theres 2 screws covered by plates near the winshield. pop em off with a blade screwdriver and then reach in there with a stubby screwdriver and take out the 2 screws.
then i think there are 2 more on the underside of the big gauge bezel piece... kind of under where the dimmer switch is on the one side and where the hazard switch is on the other side.
its been like 2 years since i did this but i think thats it (4 screws) after that the gauge bezel/cover will come off. then its pretty obvious from there. a screw on either side to hold the cluster in and then the wiring harnesses and speedo cable attached on the back
hth
Old Aug 19, 2002 | 10:45 PM
slowman's Avatar
I took way too long
Default Re: HTH do i get my gauge cluster out? (tylerspec)
hth
just put white face gauges on my car a few weeks ago. dont try taking off the plastic covering over the gauges. do it from the backside. if you need further help, contact me.
egcivicb16
Apr 5, 2006 04:31 PM
rasta420
17
Mar 3, 2003 08:21 PM
