B20 in a GS-R power steering bracket
Old Jun 4, 2009 | 10:38 AM
1point7db2's Avatar
Default B20 in a GS-R power steering bracket
So I swapped a B20 into a freinds 94' GS-R. I got the A/C to bolt up by using the GS-R bracket, but the upper PS bracket doesnt fit, and the B20 upper bracket wont fit the gsr pump. So, do I need an LS upper bracket to make the gsr pump work? Cant use the b20 pump because the fitting on the line is different.
Old Jun 4, 2009 | 10:39 AM
masijdm's Avatar
Default Re: B20 in a GS-R power steering bracket
you need LS one, because when i swapped in my RS it fitted right
Old Jun 4, 2009 | 02:56 PM
low91teg's Avatar
yes he is correct you need a ls one because the b20 is like a better version of the ls b18 !
baller status
Oct 26, 2016 09:49 PM
crexer
Mar 8, 2011 07:30 PM
GSRontheBottle
Oct 16, 2004 07:06 PM
VitaminB20
Oct 25, 2002 12:18 AM
