rear LCA sway bar nut
Old Jun 4, 2009 | 12:23 AM
rainei's Avatar
New User
Default rear LCA sway bar nut
Hello everyone, just got myself a 98 CW type R. It needs some work, so no pics yet.
Anyways, the welded nut on the LCA which the sway bar bolt goes into has stripped threads. After searching, I tried chiseling the nut off, but that didn't work too well.
I've thought of a few options.
1) Have a bodyshop remove the nut and use a different nut and washer.
2) Use a different off the shelf bolt that is much longer
3) Replace the entire LCA with either OEM or Aftermarket
If I were to replace the LCA with OEM, does buying the LCA itself come with the bushings?
What should I do?
Thanks.
Old Jun 4, 2009 | 08:57 AM
JDM_nUt's Avatar
Default Re: rear LCA sway bar nut
Have you used a impact socket yet? I had trouble w/taking off my rear lower control arms in my 95 Del Sol (RIP) its a real pain
Old Jun 4, 2009 | 09:39 AM
redlinetuning's Avatar
Replace the LCA. For the price of OEM ones, you could get yourself a nice set of aftermarket arms. They all come with bushings, even OEM.
Hatchback of Notre Dame
Suspension & Brakes
10
Mar 25, 2013 06:44 AM
jetspeedz
Aug 6, 2009 06:19 PM
GP02A
Suspension & Brakes
Mar 27, 2005 10:00 PM
CXHatchback
Oct 28, 2002 11:39 AM
