is jdm b16 xsi-II clutch (220mm and 24 spline) or different
is a clutch for a b16 SiR-II 220mm and a 24 spline or is it different i need to know asap my clutch is going and i have to order a exedy clutch kit off ebay just a stock replacement, thanks for the help
bump befor bed auction ends in 24 hrs someone inform me please so i order the right clutck kit this is what it says on the info, 12,000 miles warrenty dosnt sound bad either
----About this item
This is a brand new genuine Exedy standard OE replacement clutch kit. This clutch kit contains all the necessary components to do your clutch replacement and is the perfect setup for any stock or lightly modified vehicle. Exedy Globalparts Corporation was founded in 1923 and its clutch manufacturing business and prominent brand name Daikin Clutch are known throughout the world for supplying quality powertrain products. Exedy supplies to all 11 vehicle manufacturers in Japan as well as many other vehicle manufacturers including Honda. Exedy is the largest clutch manufacturer in Japan and their name stands for the highest in quality and performance.
This complete clutch kit includes:
Exedy Pressure Plate
Exedy Clutch Disc (220 mm, 24 spline)
Release Bearing
Pilot Bearing
Alignment Tool
Installation Guide
KHC05-EX #12
Buy from the right seller! Gripforce is the largest Exedy distributor on eBay! We gaurentee the lowest price on all genuine Exedy products on eBay. Please visit http://www.exedyusa.com/oe/dealers.asp and look for our company Speed Solution International. Note that only genuine Exedy/Daikin clutch kits (not repackaged) come with a 12 month/12,000 mile manufacturer warranty.
----About this item
Release Bearing
Pilot Bearing
Alignment Tool
Installation Guide
KHC05-EX #12
found out from my local shop, that anything 92 and newer for a B series will work. Just incase anyone comes across this i will update after the clutch is installed how well it works.
